Should the h pipe be connected?
#26
RE: Should the h pipe be connected?
No if you cut it out and weld in where it used to be. example: you are running 2 pipes ===== like that instead of a pipe in between which is called the crossover pipe. You can take it out but you will loose some power and then there is terminology but i can't remember the name.
#27
The 2 piece H pipes are usually cheaper ones. Pacesetter and Summit's H are the only ones I've really seen that split in the crossover like that. BBK, Bassani, Mac, etc, all are one piece...at least at the crossover.
breaking
10-02-2015 01:27 PM
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
