piston-valve clearance with x303?
My 5-0 has a stock lower end, i have trickflow twisted wedge with 1.6 rollers.The head gasket thickness is gonna be .039...fel-pro 1011-2. I'm going to check piston-valve clearance with modelers clay anyway...but im wondering if anyones done this combo and if their was any problems the came across?
RE: piston-valve clearance with x303?
yea u will be fine, a member on here was runnin the trick flow stage 2 cam, which is a bit bigger cam than an x303 cam, with some twisted wedge heads and he was fine. so it shouldnt be a problem, but always check
92 5.0stang
08-13-2015 06:46 AM
