no electrical at all!! i hate wiring!!! *HELP*
Old 02-23-2007, 07:22 PM
Mowin8603
Mowin8603's Avatar
Default no electrical at all!! i hate wiring!!! *HELP*
ok well i was driving my car the other day and when i went to start it the starter wouldnt stop. like it was getting electricity and wouldnt stop. so i tried drivin it home like that and the start froze and killed the motor.. or so i thought.[/align][/align]i just went out and put the car on the charger and it says that the battery is fully charged. and i know the charger works because i have charged the car with the same charger before. i check both the position connection on the battery and the coil - seems fine. and then the same with the negative on the battery and the block- again looks ok.[/align][/align]i dont have anything at all, not even a horn or my radar detector from my cig lighter.[/align][/align]i suck with wiring and HATE eletricity, so any ideas would be very helpful! [/align][/align]Thanks.[/align]
Mowin8603 is offline
Old 02-23-2007, 07:25 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: no electrical at all!! i hate wiring!!! *HELP*
checking your fuses is usually a good start
AdderMk2 is offline
Old 02-23-2007, 07:29 PM
grumpyphillips
grumpyphillips's Avatar
You might want to get a new starter solinoid if your's got stuck like that.
grumpyphillips is offline
Old 02-23-2007, 07:38 PM
redmustang83596
redmustang83596's Avatar
Either your solenoid got stuck, or you got a short to power in the starter circuit that bypassed your ignition switch. Take the starter off and bench test it. Also check your fuses, thats most likely your problem with your other things, and a short would definatly cause that.
redmustang83596 is offline
Old 02-23-2007, 07:39 PM
tjmon1
tjmon1's Avatar
Yes the solenoid can cause the starter to hang up. Also, it could be hanging up on the flywheel not allowing the armature to go back in. If the armature is hung, it will continue to run until you take off one of the battery cables. As far as no power, get a multimeter and check for voltage at the fuse box.
tjmon1 is offline
Old 02-23-2007, 07:42 PM
Mowin8603
Mowin8603's Avatar
ok so im going to go check fuses, and as for the starter.. im sure i need a new starter anyway because i bet that gear is stripped pretty good, but im going to take it off before i go buy a new one. and ill prolly end up getting a new solenoid either way.[/align][/align]update in a minuet. Thanks guys![/align]
Old 02-23-2007, 07:51 PM
Mowin8603
Mowin8603's Avatar
well the fuses all look alright. i even got the manul out and checked each one and figured out which ones they were. [/align][/align]in the manul it said something about a starter motor relay?? anyone know what and where that is?[/align]
Old 02-23-2007, 08:30 PM
5.0 MPG
5.0 MPG's Avatar
solenoid
5.0 MPG is offline
Old 02-23-2007, 08:32 PM
redmustang83596
Look at the component locations in the manual, it should be in there.
Old 02-23-2007, 09:44 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You have something that's called fusable links that run to the starter relay. If you fried them, that will cause the problem. You better also hope you didn't ruin the flywheel driving the car w/ the starter engaged.
Top right hand corner, fusable links.
PRO50SC is offline
Quick Reply: no electrical at all!! i hate wiring!!! *HELP*
