Tremec T-5?
Old 02-24-2007, 12:08 AM
ModularFox
Banned
ModularFox's Avatar
Default Tremec T-5?
Does anyone know if the stock bellhousing can be used with a Tremec T5? I tried finding some info on it but I cant find anything really. My car has had a starter/clutch/flywheel issue ever since Ive bought it and it sounds horrible when cranking over. My question was I know the car has a Tremec in it but I believe it has a stock bellhousing and a guy at work told me with the tremec trans you have to use a diffrent bellhousing and I was just wondering if this was true. Anyone know anything? Thanks.
ModularFox is offline
Old 02-24-2007, 12:10 AM
86 5.0L
86 5.0L's Avatar
Default RE: Tremec T-5?
I thought all T-5s bolted up the same? Tremec just bought Borg-warner but didnt change the design of it
86 5.0L is offline
Old 02-24-2007, 12:21 AM
grabbem88
grabbem88's Avatar
t-5 stock are still labled borge....is it a tko or 3550 or newer....if so yes you have to have a lakewood or a MCcloud....plus th e tranny hAS TO BE INDEXED
grabbem88 is offline
94gtcoupe
94gtcoupe's Avatar
ok so what i'm gathering is that your car has a tremic in it (prolly a tko), and u think the bellhouseing from the t-5 was used for the install....
if im missunderstanding this please correct me...
but if i understand this right i'll say this... the t-5 bell housing won't bold to a tremic.
tremic never manufactured a t-5 they stoped making the t-5 b4 the buy out
94gtcoupe is offline
Old 02-24-2007, 12:41 AM
ModularFox
Banned
ModularFox's Avatar
im pretty sure its not a tko, i just know with this flywheel issue i went to pull the trans tonight and its a fairly new looking aluminum trans stamped with tremec 12-51-066-999 (from what i can tell the first 2 numbers were hard to read) and i was told any tremecs cant be used with a stock T5 bellhousing and it looks like a normal bellhousing, I am not good with my 5 speed trannys and fox bodies are still new to me. When I say tremec T5 i was thinking something like this:
http://www.ttcautomotive.com/English/products/T-5.asp
Old 02-24-2007, 12:48 AM
94gtcoupe
94gtcoupe's Avatar
that link is a stock WC T-5, take a pic of whats in your car and a pic of the bell houseing... the bell housing will be very similar only the part that mounts to the tranny will be diff.
JonnyBlazeGT
11-03-2015 01:10 AM
Jskeezy84
09-08-2015 01:40 AM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
tyco
02-14-2004 10:24 PM
saleen476
01-22-2004 01:37 AM
Quick Reply: Tremec T-5?
