94gtcoupe
RE: 94gtcoupe
ORIGINAL: 94gtcoupe
rear disc is a lil diff. than fronts... the piston on the rear caliper has to be spin and it's pushed in
ORIGINAL: dimebag
yea i use a c-clamp, itll work.
RE: 94gtcoupe
yep the first time i did my rears i was like WTF is this ****... then my teacher is like here use this and it worked great.... i have to buy one when i get my new rotors
RE: 94gtcoupe
wut is so special about it? we did rear brake pads on my friends sti in class, and just used a c clamp, kept the old pad on it, and compressed it, put the new ones on and never had problems... maybe that car is diff tho
RE: 94gtcoupe
ORIGINAL: dimebag
And MOST rear disc brake cars need that special tool to compress the piston. It pushes in and twists at the same time.
The only car I know of thats isnt like any of these other ones is a probe/mx-6. On the rears there is a 14mm bolt that sits right behind the piston. You remove it and unscrew it, that pulls the piston back. Then when putting new stuff in, you screw it all teh way in until the pads just touch while turning the rotor. It should have some slight drag like a rear drum getup.
-P.
RE: 94gtcoupe
Good thing i read up on this before i replaced my rear brakes, i had no idea......I have brandnew rotors/pads that came in the trunk of the car when i bought it, only drove it for 2 montsh then put it away for winter....So it still sits But i'll need to put those on when i get it on the road again. Would a brake job tool kit have this tool in it ?
RE: 94gtcoupe
ORIGINAL: 94gtcoupe
