HELP CAN NOT HIT WOT!!!!
RE: HELP CAN NOT HIT WOT!!!!
ORIGINAL: 92hatchLX
Isn't that RPM2 upper and lower a bit too much for stock heads? Obviously you put it back together different than what it was, I'd double check it. Or you can try bending your pedal, or putting a spacer on the throttle cable.
Not to pretty right now though... Check out the current picture
http://i145.photobucket.com/albums/r...9/DSC01999.jpg
