Best Plugs with a blower
Old 02-27-2007, 01:11 PM
only90s
only90s's Avatar
Default Best Plugs with a blower
I was going to run Autolite 23s with my set up gapped at .035
Sound good or should I run 24s
Compression 9:1
Boost 10lbs
No intercooler and methanol injection has been postponed for now
only90s is offline
Old 02-27-2007, 01:33 PM
samseed101
samseed101's Avatar
Default RE: Best Plugs with a blower
You should be fine with 24s
samseed101 is offline
Old 02-27-2007, 10:24 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
No cooler? I would and do run 23's gapped @ .030 and that's intercooled.
PRO50SC is offline
Old 02-27-2007, 10:34 PM
five0fm
five0fm's Avatar
whats the difference between 23 and 24? what does it mean
five0fm is offline
Old 02-27-2007, 10:37 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: five0fm
It's the stock # of the particular plugs and in this case alse depicts the heat range.
http://www.ngksparkplugs.com/techinf...s/techtips.asp
PRO50SC is offline
Old 02-27-2007, 10:41 PM
SSKiller
SSKiller's Avatar
A stock plug is a 25. The lower the number on the Autolite's for our application means the plugs are colder.
ome cars require a hot plug. This type of plug is designed with a ceramic insert that has a smaller contact area with the metal part of the plug. This reduces the heat transfer from the ceramic, making it run hotter and thus burn away more deposits. Cold plugs are designed with more contact area, so they run cooler.
The difference between a "hot" and a "cold" spark plug is in the shape of the ceramic tip.
The carmaker will select the right temperature plug for each car. Some cars with high-performance engines naturally generate more heat, so they need colder plugs. If the spark plug gets too hot, it could ignite the fuel before the spark fires; so it is important to stick with the right type of plug for your car.
I would do what PRO said.
SSKiller is offline
Old 02-27-2007, 10:45 PM
five0fm
five0fm's Avatar
so you should gap the colder plugs smaller (.030)isnt the stock gap .054
five0fm is offline
Old 02-27-2007, 11:00 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: five0fm
On a blower car, a larger gap can produce something called blow out. this is when the force of the air rushing into the combustion chamber is so great, it can actually put out the spark. The longer the gap for the spark, the weaker the spark is. That's the reason for the smaller gaps on a blower car.
PRO50SC is offline
Old 02-27-2007, 11:06 PM
mnile9127
mnile9127's Avatar
I have 3924's gapped at .040.I had 23's at .035, but they didnt work out too
good. I dont have to worry about blow out, MSD takes care off that.
mnile9127 is offline
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
lmurf60
09-24-2015 10:07 PM
Quick Reply: Best Plugs with a blower
