Need help with ignition issues!!!
Old 02-27-2007, 04:28 PM
Montys91
Montys91's Avatar
Default Need help with ignition issues!!!
I recently bought a '91 5.0 convertible LX and it was fine for about 2 months. Then itbegan having starting problems. I would turn the key and it would just click. After I turned the key about a million times it started. I replaced the ignition soleniod and it started right upfor about 2 days then quit. Replaced it again thinking it was a faulty solenoid and it quit again. I let the car sit for about a week because I was getting the engine rebuilt, and now that it's been rebuilt, it'shaving the same problem again. I put a new battery in today and still no luck. The only thing I can think of are the grounds. Please help me out, I'm about fed up.
Montys91 is offline
Old 02-27-2007, 04:44 PM
94ford5liter
94ford5liter's Avatar
Default RE: Need help with ignition issues!!!
did you try replacing the coil? Your distributor could be bad as well.
94ford5liter is offline
Old 02-27-2007, 04:48 PM
89 fox
89 fox's Avatar
sounds like it could be starter related.....5.0's eat starters
89 fox is offline
Montys91
Montys91's Avatar
Not yet, no. I figured it wasn't even making it to the starter so I didn't want to try replacing that stuff yet. I'll probably try that tonight.
Montys91 is offline
Old 02-27-2007, 04:53 PM
Montys91
Montys91's Avatar
Just replaced the starter a few months ago. It was actually an aftermarket upgrade so it wouldn't burn out.
Montys91 is offline
Old 02-27-2007, 05:43 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
bull$hit...
has the key switch ever been replaced?
ORIGINAL: 87black snake
2 kwik is offline
Old 03-01-2007, 10:08 AM
Montys91
Montys91's Avatar
It's finally fixed. I got fed up and just went all out. I replaced the battery, battery cables, ignition solenoid, coil, distributer cap, rotor, starter, and starter cables and now it's starts better than it ever has. Thanks for all your help. Now i just have to adjust the timeing because I think it's missing a little. Thanks again!
Montys91 is offline
Old 03-01-2007, 05:06 PM
telsonman
telsonman's Avatar
that was a lot of money you just spent. it was the starter i guarantee it. whenever it just goes click, its because the starter is bad. i thought this was common knowledge... nah just kidding. but now you know
telsonman is offline
Old 03-02-2007, 08:49 AM
Montys91
Montys91's Avatar
You don't understand the frustration I was having, not to mention it was a good reason to convince the wife to let me get UPGRADES! The starter was just replaced about 3 months ago so I didn't even consider it at first. Thanks for your help though.
Montys91 is offline
Old 03-02-2007, 08:55 AM
grabbem88
grabbem88's Avatar
taking the starter off and having it tested would have been alot cheaper...you could have juped the starter,and that would have told ya the whole story
grabbem88 is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
jc409
Convertible Tech
09-26-2015 08:28 AM
Quick Reply: Need help with ignition issues!!!
