OK new problem!!!! with video
Old 02-27-2007, 10:40 PM
gearbanger
gearbanger's Avatar
Default OK new problem!!!! with video
i just fixed my throttle... but now i got a loud whistle... i think i got a gasket leak wat do you think?... the camera and sound quality is not to great but you can here the whistle..
http://s136.photobucket.com/player.swf?file=http://vid136.photobucket.com/albums/q179/PureStangs/P1010168.flv"></embed>
gearbanger is offline
Old 02-27-2007, 10:42 PM
89 fox
89 fox's Avatar
Default RE: OK new problem!!!! with video
its says...oops no video.....
89 fox is offline
Old 02-27-2007, 10:43 PM
89 fox
89 fox's Avatar
did you just install your throttle body?
89 fox is offline
Old 02-27-2007, 10:44 PM
SSKiller
SSKiller's Avatar
Take a can of WD40 and spary between the upper and lower manifolds. If the idle rises then you have a intake leak.
SSKiller is offline
Old 02-27-2007, 10:46 PM
gearbanger
gearbanger's Avatar
ORIGINAL: 87black snake
no intake manifold...
Old 02-27-2007, 10:47 PM
gearbanger
gearbanger's Avatar
i will try that..... but it only does it at idle... wouldnt it whistle all the time?
Old 02-27-2007, 10:49 PM
SSKiller
SSKiller's Avatar
I bet that is your problem. You aren't getting a good seal between the upper and the lower. Mine did the same thing.
SSKiller is offline
Old 02-27-2007, 10:52 PM
89 fox
89 fox's Avatar
+1
89 fox is offline
Old 02-27-2007, 10:53 PM
89 fox
89 fox's Avatar
this is a dumb question...but i gotta ask to cover all areas....did you install a gasket between the upper and lower intake manifold?
89 fox is offline
Old 02-27-2007, 10:55 PM
SSKiller
SSKiller's Avatar
I forgot to do that once......I was like DAMN IT!!!!!!!!!!
SSKiller is offline
Quick Reply: OK new problem!!!! with video
