Quick ECT question
Quick ECT question
When installing my trickflow intake, i believe the holes for the ECT were in different locations than the stock lower intake, and we had to cut the wire and add in a middle wire to make it reach further. By doing that, will it alter my reading from the ECT ?
RE: Quick ECT question
^[:'(] No i didnt, which i very well should have done so, Its not really too late, i'm sure i can still get to it. I was reading all throughout that fordfuelinjection.com website and came across soldering, which i shouldof done in the first place.
I think i had to move it more towards the firewall.....I think it used to be mroe to the fron of the intake.....Maybe i'm mistakin, but isnt that the only sensor in the lower intake ?
My only concern is that i sued different wire, didnt match the factory wiring, i just hope it still transfers a correct reading of volts.
As long as the gauge of wire was correct you should be ok.
The lack of solder and heat shrink will just mean that moisture will corrode the splice sooner.
The major concern with the ECT being in the back port of the lower intake is that ther is no coolant flow in that location. This may or may not be an issue, I don't know...
jason
jason
I'll see what i can do about it. Anyone know have any pics of a trickflow lower with a ECT in it ? Its been along time since ive been over to my car, i cant remember what the lower looks like.....
I'll see what i can find. Thanks fellas
Found a pic, looks like its in the right place, but there is still a wire that i cut and had to move to the back of the intake, i'll post up a pic of the wire.
[IMG]local://upfiles/24448/73BE449D5D284806B70E2B656E7945A9.jpg[/IMG]
This sensor
[IMG]local://upfiles/24448/6661060FAE514F9B9402B73569139F88.jpg[/IMG]
Dont mind the writing in the picture, its the red wire with the yellow zip tie on it in the bottom right corner of the pic, it goes to ^ that sensor, not too sure what sensor that is......But doesnt seem as important as the ECT sensor
[IMG]local://upfiles/24448/464EFF6CD9C74096914CA53A9B0D6D8B.jpg[/IMG]
This sensor
ORIGINAL: Ninety5five0
The single wire plug is probably for the coolant temp sensor.
The ECT is actually mounted on the coolant lines for the heater, toward the front of the lower intake.
I hope that clears things up better...
jason
