unknown noise
RE: unknown noise
can you narrow it down a little more? Speedo cable wouldnt sound like it was comin from the vents on the passenger side, and and exhaust leak would *probably* get louder as you accelled. sounds like sticky lifters- seafoam is your friend, even if its not the problem, its always a good idea to burn the crap out of your engine.
RE: unknown noise
i still have the smog pump, but the tube going back to the exhaust it cut off and just hanging back there, could that be whats making the noise becausei think my air pump still works.
ill probably seafoam it because ive been meaning to do that anyway. And i know its now the oil, because i change it religiously
RE: unknown noise
ORIGINAL: deanzawistowski
RE: unknown noise
all i did for now was unscrew the bowl looking fitting where the rubber hose went, beat it witha hammer and put it in a vise....it is totally seale now.....of if you wanna do it right....unscrew it from the back of the head and put a bolt.....5/8 by 11 and no longer than 3/4 in long in there
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
