help raising my lowered notch
i just recently bought a 93 notch and it sets really low and the passenger front tire rubs really bad like when i turn sharp or hit a bump in the road or sometimes when i hit the brakes hard.the front tires are 255/40/17 and the fender sets all the way down nearly on the tire so is there a easy way to raise the car about an inch or what do you think i should do, i get more rub out of the passenger side than i do the driver side.
RE: help raising my lowered notch
^^ Obviously.. but do you want to keep it lowered but just not rubbing? Check out exactally where you are rubbing at and maybe you could keep it lowered but run a different tire. If your rubbing bad though (as you described) tires prob wont do much to help you out and swapping springs might be your only option.
u need to change the front tires there way to big in the front. or go to autozone and ask about spring wedges the can help raise the car a little bit. have u taken the inner fenderwells out? or is it actually rubbing the fender itself? if its rubbing the fenders be careful u may end cutting the tires if they happen to get an edge to them
I would hate to buy new tires since the tires are in really good shape. How much would springs cost plus i like the looks of the car but it sets really low even the back fenders are right on the tires so the whole car could use a little lift.
