camaro guys in here(question)
RE: camaro guys in here(question)
They will work fine but he'll need an adjustable fuel pressure regulator so he can drop the pressure abit. The ford injectors usually cause abit of a rich condition as thier slightly larger then the stock GM's. Settingthe fuel pressureat 28 lbs. would be a good place to start.Also some people have had to grind the injector bossesabit in order to usethem, but I believe that was with the earlier TPI manifolds so he should be ok.
Just FYI theTPI and LT1 engines use the same fuel injectors.
WOW look at Mr. GM over here ... i knewthe 80's weren't the lt1's but i didn't knwo they were l98's lol
ORIGINAL: dimebag
he does not have an lt1(94-97), he has an l98...
