i've never completely removed one...but i know there is on horizontal bolt to remove where it connects to the rack. i THINK once you undo that bolt and get it off the rack...it should just slide off the steering stem like a driveshaft.
also...make sure the wheel is locked before you completely remove the shaft. if not ...you will have to reclock the steering wheel which is easy, but aggrivating
i just checked again and i see no other bolts.there are some like rivet looking things but that is is can someone get me a pic i would help alot thanks.
