water puddle
Old 03-02-2007, 11:53 PM
tom50
tom50's Avatar
Default water puddle
On the top of my waterpump where there is a little dip, water always builds up there. Not alot but a little puddle. It looks like its comming from a little whole in the back of the water pump. what could be my problem?
tom50 is offline
Old 03-02-2007, 11:56 PM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: water puddle
i did my water pump recently and it was leaking in the exact same area.
the gasket is probably leaking and when u drive down the road its collecting there
hope it aint the timing chain cover
93 LX FiveO is offline
Old 03-02-2007, 11:58 PM
tom50
tom50's Avatar
My car is just sitting on jack stands in the front and its still leaking.
tom50 is offline
Old 03-03-2007, 12:00 AM
Boss_Hotrod
Boss_Hotrod's Avatar
You dont have a chrome gooseneck do you? We do and it leaked there all the time. We finally fixed the leak using pipe dope and teflon tape.
Boss_Hotrod is offline
grabbem88
grabbem88's Avatar
cracks? it happens..also cracked stat housings
grabbem88 is offline
Old 03-03-2007, 12:02 AM
tom50
tom50's Avatar
Dont see any cracks. I am pretty sur eits leaking out of that hole cause the car is jacked up in the front. is it suppost to leak a little
tom50 is offline
Old 03-03-2007, 12:06 AM
grabbem88
grabbem88's Avatar
nope usually when a pump leaks it's a weap hole...tension spot gives out first<first sign of a bad pump
Old 03-03-2007, 12:09 AM
tom50
tom50's Avatar
Whats a weap hole? I just looked at it and the two little holes on the back top of the water pump are leaking a little. Are those the weap holes?
tom50 is offline
Old 03-03-2007, 12:12 AM
grabbem88
grabbem88's Avatar
yepper
Old 03-03-2007, 12:13 AM
93 LX FiveO
replacing that should be a priority
Quick Reply: water puddle
