upgrading to MAF
RE: upgrading to MAF
thats what i thought too, they have the 4 bolt mounts or w/e, i think im going to go with a bbk 75mm TB with a C&L 76mm and 24lb inject. with a bbk ssi intake, and trick flow heads. who knows maybe ill get a bigger cam, i appreciate everything!
I run 24# injectors on my 351W making 475hp ..... all you need is 19's
I run a 70mm TB and 76mm MAF and make over 350rwhp .......... you dont need bigger
PLEASE dont get a BBK intake, I was very unhappy with mine.
they look cool but they suck
Trickflow Street Heat intake is best bang for the buck
The Holley Sys II intake has awesome flow numbers too.
www.tmossporting.com can make you stock or Cobra intake flow like a ***** too
ORIGINAL: 92hatchLX
vristang, aren't the connections or something different on the 94-95 MAF's?
Isthe Cobra upperplenum opening large enough for a 70mm TB?
Why not go with a TF street heat or something that's got a little more flow than the Cobra?
I believe the cobra is sized for a 70mm, but it has been a long time since I used a cobra upper.
I guess I missed the part where the intake was being discussed (I am barely awake right now...)
If buying a new intake, why not get the best flowing one available.
If you already have the cobra though, just work with that.
My response was intended to get good performance AND drivability for a decent cost.
jason
jwog666
12-27-2021 08:09 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
