Cobra Vs Stock INtake
RE: Cobra Vs Stock INtake
The new Cobra intakes are made in China and lesser quality. Go to a junkyard and grab the intake off a 5.0 Exploder motor, it's the same thing. While your at it, grab the heads too and you'll definitely notice a power difference.
W/ stock heads, anything bigger than a 65mm TB is overkill. The heads can't flow enough to keep up. If you plan on upgrading the heads, then 70 will be fine....you'll want to get a larger MAF, though. The stocker is only 55mm.
11-10-2015 11:39 AM
09-01-2015 08:16 PM
