rust is a beotch
Old 03-02-2007, 02:32 AM
88ttop5.0
88ttop5.0's Avatar
Default rust is a beotch
Whos dealing with rust on there fox?, what is the best way to get rid of surface rust and about how much does it cost to pay to have it done at a body shop maybe sandblasting ? any help from professionals or people with insight is greatly appretiated i also have a spot that is sorta rusted through were the fire wall meets the fender mounting location??? best solution for that? TY
88ttop5.0 is offline
Old 03-02-2007, 02:44 AM
Twisted
Twisted's Avatar
Default RE: rust is a beotch
I'd like to know also. I have a blister or two here and there.
Twisted is offline
Old 03-02-2007, 02:50 AM
93 LX FiveO
93 LX FiveO's Avatar
well i am no expert but ive heard working ur way up from a low grit to a high grit sandpaper can get the surface smooth again if the rust isnt all the way through. if you got rust holes you may be looking at patching/welding or even just replacing depending how bad.
make sure ur car has no other rust (under the paint) otherwise u may be wasting ur time
93 LX FiveO is offline
Old 03-02-2007, 02:56 AM
88ttop5.0
88ttop5.0's Avatar
yea but how do u determine that or should i just throw out some money to a body shop im lookin for the most practical aka affordable best way of restoring the body to a good condition without cutting corners?
Old 03-02-2007, 03:05 AM
93 LX FiveO
your best bet would be to just strip the paint, fix up the body and primer it.. then paint it when the funds are there
u can go fast and look bad but if u look good u better be goin fast
catch my drift?
Old 03-02-2007, 03:26 AM
5.slow33
5.slow33's Avatar
hey man if you got rust on the wheel wells you better pull the budy trim off cuase i bet there is a ton more under there cause if you just do it up to trim give it a week and it will back
5.slow33 is offline
Old 03-02-2007, 03:45 AM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
ORIGINAL: 93 LX FiveO
catch my drift?
hells ya man, sleepers FTW!
90mustang5.8 is offline
Old 03-02-2007, 04:25 AM
88ttop5.0
88ttop5.0's Avatar
i catch ur drift i can prolly save some money if i strip the car down and then bring it for prep and stuff i guess thats what ill do w/e gotta get the funds first.
Old 03-02-2007, 05:16 AM
Evil_F
Evil_F's Avatar
Steel Brush Wheel works 2nd best when compared to blasting. You can get them cheap and put them in a drill. They will really knock off the rust. Rustoleum primer can help also. That is what I am doing. Except I wont be putting show quality paint on top of it.
Evil_F is offline
Old 03-02-2007, 10:02 AM
86HOGT
86HOGT's Avatar
The only rust I had was on the hatch and those get worse than you think when you strip them. Fiberglass hatch, FTW[:-]
86HOGT is offline
Quick Reply: rust is a beotch
