What heat range plug - MustangForums.com
Old 03-02-2007, 05:11 AM   #1
smokesricers
Default What heat range plug
I want a step colder spark plug to use with my 125 shot but what heat range is it that i need? I cant find it anywhere? Thanks!
smokesricers is offline   Reply With Quote
Old 03-02-2007, 03:22 PM   #2
samseed101
Default RE: What heat range plug
With that setup, I'd run autolite 24s.
samseed101 is offline   Reply With Quote
Old 03-02-2007, 03:36 PM   #3
93stallion302
Autolite 23's is wat im switchin to on a 100shot. idk if 24's are too hot or not better safe than sorry.
93stallion302 is offline   Reply With Quote
Old 03-02-2007, 03:40 PM   #4
samseed101
Running a colder range it not necessarily the "safer" option though. Don't forget that if you run a plug that's too cold, you could end up fouling your plugs and they become useless. With a supercharger and a 100 shot of nitrous my autolite 24s are right on the money. I actually just happened to pull a plug last night to test it and it looked great.
If you run a plug thats too cold and if you happen to run a little rich...forget about it. Might as well toss the plugs now because they probably won't last long.
Old 03-02-2007, 04:03 PM   #5
92GreyGT
When I ran spray Nitrous Express told me that I didn't have to run a colder plug unless I went over 150 shot. I may have to run a colder plug but not to golower than one heat range. I ran 25s and never had a problem running 150 shot.
92GreyGT is offline   Reply With Quote
Old 03-02-2007, 09:44 PM   #6
smokesricers
I have a set of platinum autolites (ap764) and its says the heat range is 4. Can i use these? Is this the same as "24's"
Old 03-02-2007, 10:41 PM   #7
2 kwik
I ♥ Acer
if your not reading it after a wot blast then you not see $hit
Quote:
ORIGINAL: samseed101
2 kwik is offline   Reply With Quote
Old 03-02-2007, 11:32 PM   #8
SSKiller
Run and autolite 23.
SSKiller is offline   Reply With Quote
Original Owner 1970 Mustang b8checker Classic Mustangs (Tech) 8 10-08-2015 12:55 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 05:54 PM
Original Owner 1970 Mustang b8checker New Member Area 3 09-30-2015 07:11 AM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 11:10 AM
150, 165, 50, 50l, 93, afr, ap764, autolite, cold, cooler, ford, heat, mustang, nitrous, plug, range, run, shot, spark
