39#er cobra injectors
Old 03-02-2007, 07:13 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default 39#er cobra injectors
will 39# cobra injectors support a h/c/i and 10psi vortech charger.... also injectors are interchange able between the years rite??? im pretty sure there off an 03 or a 04 cobra but arent they all the same??
CrazyCobraSpeed is offline
Old 03-02-2007, 07:17 PM
grabbem88
grabbem88's Avatar
Default RE: 39#er cobra injectors
as long as the injector driver plugs into your harness it should...39's with supporting fuel system upgrades will be fine...if you hit 600hp i'll be concerned if your fuel lines and rails can support it
grabbem88 is offline
Old 03-02-2007, 07:31 PM
CrazyCobraSpeed
i dont want much if ne mroe than 450rwhp so im guessin those a regulator and a 255lph fuel pump is what i need for my fuel system
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
88 orangepeel notch
10-05-2015 09:03 AM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 39#er cobra injectors
