water puddle
03-02-2007, 11:53 PM
water puddle
On the top of my waterpump where there is a little dip, water always builds up there. Not alot but a little puddle. It looks like its comming from a little whole in the back of the water pump. what could be my problem?
03-02-2007, 11:56 PM
RE: water puddle
i did my water pump recently and it was leaking in the exact same area.
the gasket is probably leaking and when u drive down the road its collecting there
hope it aint the timing chain cover
03-02-2007, 11:58 PM
RE: water puddle
My car is just sitting on jack stands in the front and its still leaking.
03-03-2007, 12:00 AM
RE: water puddle
You dont have a chrome gooseneck do you? We do and it leaked there all the time. We finally fixed the leak using pipe dope and teflon tape.
RE: water puddle
cracks? it happens..also cracked stat housings
03-03-2007, 12:02 AM
RE: water puddle
Dont see any cracks. I am pretty sur eits leaking out of that hole cause the car is jacked up in the front. is it suppost to leak a little
03-03-2007, 12:06 AM
RE: water puddle
nope usually when a pump leaks it's a weap hole...tension spot gives out first<first sign of a bad pump
03-03-2007, 12:09 AM
RE: water puddle
Whats a weap hole? I just looked at it and the two little holes on the back top of the water pump are leaking a little. Are those the weap holes?
03-03-2007, 12:12 AM
RE: water puddle
yepper
03-03-2007, 12:13 AM
RE: water puddle
replacing that should be a priority
