Shot Engine Mounts
Shot Engine Mounts
So my engine mounts are shot. How bad is this affecting the car? Is this going to make it go down the track worse? Would I be better off getting solid mounts? I drive the car pretty often, but I want the best performance possible.
RE: Shot Engine Mounts
if you get solid mounts you would never forget it haha... talk about a vibrating machine haha
one thing i noticed with my bad mounts was, when i was driving in first gear at a higher rpm, and let off the gas, it would have play in it... like a clunk thing
ORIGINAL: rmodel65
normaly ull really know whenwhen the fan bust the fan shroud[8D] ull notice alot of vibration and posibly a knocking noise when u really get on it
well, i guess my mounts are good then![8D]
ORIGINAL: Li0nHart
do not use a solid mount for street use...you will fatigue and crack your k member eventually...prothane all the way
