electric throttle linkage
i went to adjust my idle by the screw and to the touch i feel a slight shocking charge, not to bad. but still not normal. my sparkplug wires are new and tucked away not touching... any ideas where this might be comming from?
also, i am in need of getting my car smogged soon, and suggestions on passing.. i read after searching that i could bump back the timing, lower idle... is there a way i could check my timing without a timing light?
RE: electric throttle linkage
so i just went to check it and its not doing it anymore. next time it happens ill measure it.
i let the car run for a little to warm up while i tested it, when i turned the car off i hear a dripping sound, like water driping into more water sort of thing. except i dont think its water, it was comming from around the upper intake i think... any ideas?
mrappe
09-26-2015 10:16 AM
TfcCDR
09-14-2015 12:08 PM
