window trim
Old 03-03-2007, 01:23 PM
JABES
JABES's Avatar
Default window trim
does anyone know how to remove the windshield trim without bending it and screwing it up
[align=left] [/align]
JABES is offline
Old 03-03-2007, 03:22 PM
Li0nHart
Li0nHart's Avatar
Default RE: window trim
I used a screw driver...it takes a long time but if you carefull pry it up you will see the little clips that are atached to little pegs. Gently pry jsut to the side of the clips and the trin should pop out and leaveth clip behind.
There is a special tool you can get for this job...i've never actually seen one so i don't even know what they look like...i'm sure some one will pipe up and let us know what it is...
to get the windhield out, use a piece of string...start in one of the corners and carefully poke a peice of wax string, or if you are carefull you cna use a piece of mig wire, throguh the tar goo that seals thei window. then slowly work your way around the widow untill its free.
then you get the fun job of scraping all the goo of the window channel...be warned...do not crape off the paint or it will start to rust and cause a leak...if you do scrape the paint off..POR-15 it before you re-goo and reinstall the window.
Li0nHart is offline
Old 03-03-2007, 11:52 PM
riley6riley
riley6riley's Avatar
I took some trim off on my door and broke the little white clips you are talking about. Do you know where I can get new ones? I have checked the dealer and searched all over the internet.....no luck.
any help would be appreciated.
riley6riley is offline
Old 03-04-2007, 10:50 PM
stang8689
stang8689's Avatar
I do auto glass for a living the toll is cheap go to www.equalizer.com they have it it has an A shape, works great
stang8689 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
b8checker
10-08-2015 12:55 PM
mdg
10-01-2015 07:04 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: window trim
