ps pump moving question
alright i am rebuilding the motor and tranny on my 88 mustang im removing ac and smog pump. i have seen the power steering pump moved to were the ac was. can someone tell me how to do that. and do i have to get longer lines and how big of a belt do i need? can you guys give me a guestimate on power as well stock rebuild removing smog and a/c as well as heads milled 12 thousandths with a 3 angle valve job. any help would be greatly appreciated thanks
RE: ps pump moving question
youll need something around a 70.5 (with underdrive pullies) inch belt give or take an inch everyone seems to be a little diffirent
as for reloacating the PS pump you can buy a special bracquet from summit i think ford racing makes it
[IMG]local://upfiles/41517/8CA0AAEE062B48D2862D2FABC2F1CE7A.jpg[/IMG]
ORIGINAL: 88mustangturd
o that sucks. is it possible to leave the power steering pump were it is at. if im running no ac no smog pump? just alternator crank water pump and ps pump? and do you have a idea on the hp tyhing
