c clip eliminators???
ok i have a 91 lx aod and its going in for some gears soon. my question is would it be a good idea to have a set of c clip eliminators while its apart. or its not really needed? its just a daily driver
RE: c clip eliminators???
ORIGINAL: fordstroker
Not needed for a daily driver, you will need to cut off some of the axle housing, have the c-clips pressed on to the axles by someone who knows what they are doing.
ORIGINAL: PRO50SC
You know, this is an interesting topic. I've heard the same, but I've also heard nothing needs to be cut from another shop. Hmmmmmmm?????
Maybe so, but just relaying what I was told
PM from a shop on another site
Originally Posted by PRO50SC[/align]
Quote:[/align]
Originally Posted by mmeracing[/align]
Quote:[/align]
Originally Posted by PRO50SC[/align]Hey do you guys install them. I hear you have to have the axle tube ends cut off. If so, what do you all charge to do this? 92 Mustang LX 8.8 rear.
Thanks,
Bernie[/align][/align]
Yes we do install them, C-Clip elim do not require the tubes to be cut. If you install 9" tube ends and a set of 9" brakes then the tubes must be cut. To install a set of c clip elims on a 8.8 would be about 225.00 plus the kit. If memory serves me right the kit is about 130.00.
Thanks, Mark[/align][/align][/align]
Thanks,
Yes, true you dont cut the ends off, the only time to cut the ends off would be for 9" ends which eliminates the use of c-clips, but you do need to cut off about 2 inches right to the backing plate register. If needed I can get a pic.
