Transmission Oil
RE: Transmission Oil
ORIGINAL: Mustangn
When should the transmission oil be replaced.?
I have a 1991 GT with manual trany,all stock with 54K Original Miles.
good idealets just not change our tranny fluid untill somethings broke in it thats a good idea... i donno maybe u read that wrong or something but no changing fluids is one of the dumbest things to do... the manual says 100,000 miles.... i suggest the first change to be75,000-100,000 andevery50,000 after the initial fluid change... om a rebuilt tranny i suggest after 1000 miles then every 50,000 after that
ORIGINAL: FullAuto
If it ain't broke, don't fix it.
thats a matter of opinion, i recomment GM syncromesh (what i personaly use), or another name brand full synthetic, syncromech is the only half synthetic that i like and acutalu works better than other full synthetics i've used
every 30,000 if a auto and every 50,000 if manual
on aod, c4 or any ford auto use mercon3 I change the filter every 30k and get the system flushed every 60k.
manuals either take mercon or gear oil check you service manual for proprer fluid
ORIGINAL: 94gtcoupe
