5.0 rebuild cost
5.0 rebuild cost
How much should I expect to pay (or how much did you pay)for a basic long block rebuild? Every thing will be stock except for pistons that will be able to clear larger valves and higher lift.
RE: 5.0 rebuild cost
Depends on what all you are considering changing, upgrading, etc. Rings are usually 75 bucks or so, and mains and rods usually run ya around 50-75 with stock sizes. Gasket kits cost usually around a hundred bucks for every gasket on the motor... Less than 500 when all is said and done is a good figure if you do the work yourself... That's a good round number to expect to see, because it is never as easy as it seems
If you don't have to have the crank turned, or buy a rebuilt one, you should get out pretty cheap... The good thing about a reman crank, or a new one, is you get matched bearings... Depends on the builder, its hard to say because of rates, but it can get pretty expensive having someone else do the work
i know 5.0's are a lot cheaper than most other cars, but i had to rebuild a 3.8 SC outta my '00 Grand Prix GTP, and i had it all done and after everything said and done out the door was like $3,200. so i know its going to be a hell of a lot less than that lol.[/align][/align]..another reason why i sold that and got a stang [/align]
Matt's 95 Stang
10-05-2015 07:16 AM
