Best Top End Build
RE: Best Top End Build
A construction contractor hires 3 day laborers to help out on a job; a Russian, a Mexican and a Japanese guy. He tells theRussian he is in charge of the dirt. He tells the Mexican he is in charge of the rock. He tells the Japanese guy he is in charge of supplies.
At the end of the day, the contractor comes back to check on progress. He sees a huge pile of dirt and says, "good job, Russian." Then he sees a big pile of rock and says, "good job, Mexican." After a few seconds of looking around he asks, "where's the Japanese guy?" All of the sudden, the Japanese guysjumps out from behind the huge pile of dirt and yells, "SUPPLIES!"
i got the Edelbrock Performer RPM manifolds $600 operating range 1500-6500RPM
I got Edelbrock RPM 170cc 2.02Valve heads instead of AFR185's just because of the price. Edelbrocks are about $300 cheaper give or take a little. The AFR's needs a spring upgrade from what i have been told. Edelbrocks heads $1,282 polished. since it will be a daily driver get a cam thats got a range from about idol or 1500 to 5500. the higher the top end RPM for the cam the slower your take off will be with out a higher stall or dumping it. comp, lunati, and crane make good cams.
