Seafoam, Where?
Old 03-05-2007, 02:03 PM
LCBlackDep183
LCBlackDep183's Avatar
Default Seafoam, Where?
Where did you all purge the sustem to let the seafoam work its way into the intake and rest of the engine equally... And HOW THE HELL do you get to the pcv valve to change it without taking off the upper intake...
LCBlackDep183 is offline
Old 03-05-2007, 02:27 PM
89 fox
89 fox's Avatar
Default RE: Seafoam, Where?
i always crank the car and let it suck it out the can through the brake booster vacuum line
89 fox is offline
Old 03-05-2007, 03:46 PM
HACKGT350
HACKGT350's Avatar
with the car running pull the brake booster line off and poor in about half of it through there turn the car off and let it sit for a good 15 min while your waiting poor the rest into your gas tank start the car might take a while took my a while to finally get it to start and then sit back and watch the smoke show
HACKGT350 is offline
Old 03-05-2007, 03:48 PM
HACKGT350
HACKGT350's Avatar
oh and dont forget to plug the hose back on before you restart the car
Old 03-05-2007, 03:58 PM
88BlueGT
88BlueGT's Avatar
+1 on BB line.
88BlueGT is offline
Old 03-05-2007, 04:39 PM
mcginnt
mcginnt's Avatar
where is this BB line located at?
mcginnt is offline
Old 03-05-2007, 05:48 PM
samseed101
samseed101's Avatar
The brake booster line is located on the vacuum tree on the driver's side of the vehicle near the firewall. You'll see several hoses attached to it. The brake booster line is usually lables "B/B" on the tree.
As far as how to remvoe the PCV... I have to come in from the p[assenger side to get to it. And I have to make sure the engine is cold because it's a tight squeeze and gets hot back there/ Keep in mind that it's only held in by friction (in the grommet) so all you have to do is pull on it and it comes out. When it's time to put one back in, just push firmly.
samseed101 is offline
Old 03-05-2007, 06:49 PM
92notch88
92notch88's Avatar
make sure you give it a nice hard run after you let it sit to get all of the smoke out
92notch88 is offline
Old 03-05-2007, 06:56 PM
88BlueGT
88BlueGT's Avatar
Your supposed to let it idle while the smoke it comming out. Of coarse I give it a few nice revs for amusment but I dont think your supposed to drive it. Also, make sure you have a good exhaust system on your car if your doing this... no shot mufflers & clogged cats.
88BlueGT is offline
Old 03-05-2007, 07:20 PM
HACKGT350
HACKGT350's Avatar
haha i had to drive mine it wouldnt stop smoking for a good hour, the real big part of the smoke had passes but it looked like i was burning oil really bad even though i wasnt
Shadow7874
09-24-2015 09:06 PM
TfcCDR
09-14-2015 12:08 PM
jpplaw
08-22-2015 09:29 PM
SXGT
13
11-15-2006 02:59 AM
pallidamors
12
09-17-2006 07:41 PM
Quick Reply: Seafoam, Where?
