Leaking Oil
Leaking Oil
Not sure what happened my 91 GT has been in the garage for about 3 monthes now. Warmed up here over the weekend so I went out to start it just to warm it up. After about 5-10 minutes I shut it off and noticed a small drip. Checked it out appears to be oil. How does something like this happen while just sittin? Any ideas of what might be wrong?
Thanks in advance
Thanks in advance
RE: Leaking Oil
alot of cars leak a small amount of oil. it can also be tranny fluid, power steering fluid, coolant. It all depends on where it is coming from if it is really a problem. Like mine leaks at the rear main seal, and if i drove a 5 speed this could be a problem caus oil+ clutch = bad news.
RE: Leaking Oil
I'm picky about thats stuff I guess .Maybe it becuase I like knowing my stuff is right if it has a leak I wont drive it weather its oil , coolant , trans , or power steering. even a header gasket annoys me . I just go over my car with a fine tooth comb
bradleyb
11-27-2015 07:50 PM
