what size tb?
Old 03-05-2007, 04:36 PM
bighungrymatt
bighungrymatt's Avatar
Default what size tb?
I was wondering what size throttle body I should go with. I have bbk shorty headers, magnaflow full exhaust, and procharger supercharger. I was thinking 70mm? give me some suggestions
thanks
bighungrymatt is offline
Old 03-05-2007, 04:37 PM
88BlueGT
88BlueGT's Avatar
Default RE: what size tb?
70mm would be fine. Are you running the stock MAF still?
88BlueGT is offline
Old 03-05-2007, 05:03 PM
FullAuto
FullAuto's Avatar
What intake?
FullAuto is offline
Old 03-05-2007, 05:22 PM
bighungrymatt
Yeah I still have the stock MAF, I will upgrade that too, any suggestions?
Old 03-05-2007, 05:31 PM
88BlueGT
88BlueGT's Avatar
+1 on the intake.... if you are still running the stocker isnt the opening only 65mm?
88BlueGT is offline
Old 03-05-2007, 05:38 PM
bighungrymatt
Im not sure what the stock opening is. What should I upgrade to on the MAF?
and how much gains should I expect to gain..?
Old 03-05-2007, 05:43 PM
LTnone
LTnone's Avatar
I might be mistaken, but I believe the stock TB is 58mm[:@]. a 70 will be perfect for your application, and definitely get a 70+mm MAF. Your air can only flow as quickly as your smallest opening will allow. That stocker is a bottleneck
LTnone is offline
Old 03-05-2007, 05:50 PM
bighungrymatt
good deal, thanks for your help
Old 03-05-2007, 05:57 PM
LIL D
LIL D's Avatar
i was always recommended to have a bigger maf thanthe throttle body
LIL D is offline
bighungrymatt
so maybe a 75mm MAF if I go 70mm TB?
Quick Reply: what size tb?
