Oil change
Old 03-05-2007, 09:04 PM
Obituaries
Obituaries's Avatar
Default Oil change
Curious what type of oil you guys run in your 302's. I tried several searches and came up with nothing solid. Im in FL and appreciate any input thanks.
Obituaries is offline
Old 03-05-2007, 09:09 PM
samseed101
samseed101's Avatar
Default RE: Oil change
I'm gonna dump in some Mobil One Synthetic once spring gets here. If you can afford it, Royal Purple kicks ****!
samseed101 is offline
Old 03-05-2007, 09:14 PM
Obituaries
Obituaries's Avatar
Yea I got the conventional / synthetic thing covered thanks though. Was more curious about viscosity and weight. Im more familar with the modular engine family which has some pretty tight tolerances and 5w20 is recommended.But I just bought myself an 89 LX for a daily driver, thats why im questioning.
Old 03-05-2007, 09:17 PM
Li0nHart
Li0nHart's Avatar
where i'm from most peeps run 5w30 year round as it gets cold in winter...it's ok if your engne is in good shape otherwise it smokes a bit when first starting up cold.
Li0nHart is offline
Old 03-05-2007, 09:19 PM
Obituaries
Obituaries's Avatar
I see, I had someone suggest 20w50.....figured that was a little thick.
Old 03-05-2007, 09:23 PM
PONY GUY
PONY GUY's Avatar
I run 10w40 in the winter and 20w50 in the summer
PONY GUY is offline
Old 03-05-2007, 09:24 PM
Li0nHart
Li0nHart's Avatar
20w50 is a bit thick for a 302 unless you got bad valve guides and rings...where you are, you are probably fine with 10w30 all year..i'm no expert on synthetics so someone else will have to suggest those for ya..
Li0nHart is offline
Old 03-05-2007, 09:28 PM
Obituaries
Obituaries's Avatar
I'll probably just keep it conventional. Id assume thats what the previous owner had been running through it and for how long I don't know. The motors in great shape too, so maybe I wont run something that thick.
PONY GUY
PONY GUY's Avatar
if its got alot of miles on it dont use synthetic stick with regulare oil it may cause problems since its so thins such as oiling problems, or seals starting to leak . just run regular 10w30 and you'll be fine
PONY GUY is offline
Old 03-05-2007, 09:29 PM
Obituaries
Obituaries's Avatar
Thats what I've been leaning towards. Thanks for all the replies.
2007StangV6
01-28-2016 06:09 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil change
