Valvetrain Geometry
Valvetrain Geometry
I thought I had the right length pushrod but then I read that you need to use a solid lifter to check the geometry, is that necessary? Do my lifters really compress as they open the valve? I was sure the stock length was going to be correct and that I just had to get some hardened ones.
Setup: AFR 165s (pedestal mount), Steeda #19 Cam, stock 1.7 RRs
RE: Valvetrain Geometry
Youneed touse a solid lifter, you only need to purchase one though. Or I have heard that you can flip the cup (the part where the pushrod seats onto the lifter) upside down and do it that way. I'd personally just go out and buy a solid lifter.
Make one, or two........ http://www.trickflow.com/articles/stroker_1/# (3rd. paragraph).....and follow the procedure at Valvetrain Geometry
ORIGINAL: Joel5.0
take a old one and take spring out and cram full of what ever to hold it closed and not give///use it...i out a buncha bbs in it and closed it and it was as good as a solid lifter... what ever ya solid lifter measures,then the good lifter will not push the pushrod down more,the good plunger on good lifterwill collapse and wont push as far as a solid..
ORIGINAL: hellas85stang
