Any Ideas?
Any Ideas?
I installed 30lb. injectors,a meter, and a 255 fuel pump and now when I lay into it the car loads up and falls on its face. I tried lowering the fuel pressure to 32 with no change. The only thing I can think of is buying a MSD box to help the fire. I installed new plugs and gapped them to 28, once again no luck. I can rev the engine in nuetral and it does fine. I can also climb the RPMs slowly and it will do alright. But I cant lay into it. It is stock ignition, but I was told it should be alright. Any ideas?
RE: Any Ideas?
ORIGINAL: 2 kwik
those 30's can work.....pull battery cable off..neg. one for about 30 mins
RE: Any Ideas?
The neg cable resets the computer, not the pos. 30 minutes, then hook it back up and start your car for 2 minutes with all accessories off. Than shut it down for 2 minutes and start it again with all accessories on.
