Procharger running of the Serpatine belt???
This guys tryign to tel me he's running his procharger along with his serpatine belt thats running his other accessorys.? this true i thoguth u need'd a crank pulley
RE: Procharger running of the Serpatine belt???
I'm not sure what yore asking, but it sounds like you are asking if you use the serpentine belt to run the supercharger pulley. If that is indeed what you are asking, then yes that is how it is often done. The same belt that runs your water pump, smog pump, alternator, power steering pump, etc is teh same belt that runs your procharger supercharger. You can run a seperate belt, but it takes some fabricating.
I was going to switch mine around so that it was seperate, but it would take some work and it wasn't worth it for me. It's cramped enough in there as it is without adding more pulies! LoL
Hell, I'm still trying to figure out a better way to run the intake for it.
sounds kewl.. well the guy i bought my procharger of off. told me on his 4.6 he just ran it with the other pulleys.. and i just never seen one like that. But sounds kewl. Im going to make my own bracket right of my driver side head i think. Cuz procharger wants 400bucks for the dam bracket and crank pulley.. thats rediculous. Im just going to get like 1/2 thick stainless steel or somthing and cut out apiece to bolt the procharger to my driver side head. Also he told me on 4.6's he showed me the piping, and what he was talking about. theres a extended lil piece of pipe that has like a waste gate attached to it with a airfilter attached. He said to just weld a normal waste gate onto the pipe. What size waste gate or are they all the same? Im going to have some fab work to do with piping thats for sure. I think ill just buy a couple 90's ,45's and some stright pipes of ebay. Then get a silcone kit of rubbers. Im just going to use hose claps. Im going to mount my MAF in my fender. I still need to mount the waste gate but trying to think of were. I think its going to look good when its done. Cant wait. I got some more polishing to do. Im going to take my time. He said it will be dull in 3 weeks. Looks like ill be cleaning alot. Oh well, it will be worth it.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Dragonus18
09-09-2015 01:21 AM
