351w
Old 03-07-2007, 07:26 PM
r.barn
r.barn's Avatar
Default RE: 351w
stay away from those ebay piece of craps
www.hpperformance.com is the turbo kit you want for a 351W
r.barn is offline
Old 03-07-2007, 07:57 PM
Cleeman99
Cleeman99's Avatar
Default RE: 351w
what would happen if u ran this on a stock 351w
Cleeman99 is offline
Old 03-07-2007, 08:11 PM
r.barn
r.barn's Avatar
Default RE: 351w
massive load end torque, some good top end power.
be better off just putting it on a stock 302 if you're just going to be
putting in a stock 351W, stock 351 only made about 40 more hp.
r.barn is offline
Old 03-07-2007, 08:40 PM
Cleeman99
Cleeman99's Avatar
Default RE: 351w
no if i was going with the 351w it might be the block stock have the heads proted or get a set of victor Jr. heads
Old 03-07-2007, 08:52 PM
r.barn
r.barn's Avatar
Default RE: 351w
ORIGINAL: Cleeman99
stock block, good internals, good heads and proper cam with that HPTurbo running 10psi
will put you around 550+rwhp .......... give or take, very wicked, I plan on one soon myself but probably only 7psi
due to my 10:1 compression. If you put in super strong rods you could kick it even higher on
the boost but over 550rwhp and you're pushing a stock block.
would probably want to do thier 66mm turbo upgrade
r.barn is offline
guitarman376
09-30-2015 05:54 PM
LiquidDrink
09-29-2015 10:06 AM
FoxGT
07-11-2004 11:49 PM
Mustang88LXKid
02-29-2004 08:01 PM
WNDSOR
01-30-2004 09:47 AM
Quick Reply: 351w
