average cost of an engine rebuild
RE: average cost of an engine rebuild
We could guess I suppose, but I think you should find a good shop, and ask them. Would I get in trouble if I linked to an interestingpost on this subject on a different Mustang site?
If your just talking about the cost of professionally assembling an engine from the intake to oil pan, the average is approx $600.00. This pricedoes NOT include the cost ofany parts or machine work just assembly.
There is no need for any 5.0 engine to need anything but a good torque plate honed with a .030 over flat top piston. Even then the 5.0 engine bores are almost always with in a half thousands wear in the cylinder bores. Most cases a ring job , and new valve springs five angle valve job, your choice is all that is needed on the short block. your choice on valve sizes. $200.00 for ring kit, 2 to $500.00 on the iron heads. And or buy the pro comp Aluminum off eBay for $549.00. $750.00 or so dollars. That's what I'd do and have done and it work's out great. I hope this help's you get what your after.
