What is a "Puller"??
Old 03-07-2007, 10:01 PM
BlazeGT
BlazeGT's Avatar
Default What is a "Puller"??
Im currently breaking down my 351w engine, trying to get to the block so i can rebuild it. There is a rather large bolt that i cannot get off on the crankshaft damper. In a book i have on rebuilding motors it says i need a puller. The only problem is i have no idea what that is so if you can help me out id appreciate it. I know its a noob question but thanks for the info.
BlazeGT is offline
Old 03-07-2007, 10:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: What is a "Puller"??
It's similar to this.
Once you remove the crank bolt, you will need something to get the pulley off with.
PRO50SC is offline
Old 03-07-2007, 10:11 PM
ZachW04Stang
ZachW04Stang's Avatar
You need to hit that bolt that holds the balancer on with a impact gun or its pretty hard to get off. I've used a breaker bar jammed between to crankshaft pully bolts and a breaker bar to get it loose before. Then like pro said use the puller pictured above to pull it off.
ZachW04Stang is offline
Old 03-07-2007, 10:32 PM
silver91gt
silver91gt's Avatar
I heard of someone using the starter to take it off by putting a big ratchet with a breaker bar under thepassenger framerail and turning it over for a second.
I use air tools though
and thats not the right puller, only use one of those if you are replacing the balancer cause it will wreck it.
use a puller like this
http://store.summitracing.com/partde...p;autoview=sku
silver91gt is offline
Old 03-07-2007, 10:38 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: silver91gt
Do you know what the word "similar" means. Thanks!!It was the first one that came up in the GOOGLE search!!!
Next!!![&:]
PRO50SC is offline
Old 03-07-2007, 11:01 PM
silver91gt
silver91gt's Avatar
ORIGINAL: ZachW04Stang
easy there pro,
Urambo Tauro
09-07-2015 12:47 PM
Toddman0025
08-11-2006 10:37 PM
JamesTronix
SVT Forums
07-29-2006 05:19 PM
1stgear
07-25-2006 12:21 AM
Cedarkill
11-12-2004 10:51 PM
Quick Reply: What is a "Puller"??
