5.0 help
Old 03-08-2007, 12:22 AM
82stang
82stang's Avatar
Default 5.0 help
ok so my car is an 82 gt, the car idles like ****..... i pulled the valve cover off since it started leaking onto the headers, the top of the head is full of grime so i plan on running 1 qt of kerosene in the oil to try and clear it out i may do it twice, then change the oil a few times, ok so now i need two new valve cover gaskets, not a prob., i pulled the carb off and vac lines are crazy everywhere,the emissions air pump was pulled off and half the lines were left alone, so i need help finding out what all the components of the smog control is so i can pull it completly off...... and i may buy the pump eliminator kit for the pulley because im having problems finding a belt to fit correctly maybe i can find someone that can fabricate me one that will work, so after reading all this my main goal is i need to know what is the minimum air vac lines needed to run the motor eliminate all the other junk i may even pull the ac off to clean up more room, ive searched for diagrams but nothing good helps, and everything is for like 88 and up, i dont know the main diferences in the years but please all help is appreciated, or if someone is located in fredericksburg va and would like to stop by and just give some input would be great
82stang is offline
Old 03-08-2007, 08:53 PM
82stang
82stang's Avatar
Default RE: 5.0 help
nothing
82stang is offline
Granatelli Sales
03-25-2016 08:01 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 5.0 help
