has anyone done this
PRO50SC, i tried the search i could find anything
..has any one with their notch put like a 10" or 12" subwoofer in the place were the spare tire goes, then cut a round hole in the carpet to make it look nice? i might try it and want to see if anyone has done it b4 for help.
-tnx.
-tnx.
RE: has anyone done this
we have an audio section... and if u do that u have to make a fiber glass enclosure for the sub to fit in or the sound won't radiate out right and it'll sound like ***
subs need proper box specs to sound good. I tried taking mine out of the box the other day (its in a huge truck box that has to sit flat in my trunk) and just sitting there it sounded terrible. Anythign i could find to put it in still sounded terrible. So mines back in the big heavy box again.
I think it would be very easy to make a box to fit in there and work ok. I know others have put a sub there. The only problem is it will send the sound upwards and not toward to people listening. You would still get some of the base, but it would not be the same as if the sub was facing forward. It you do build the box you might want to get the sub first just so you can have the info for the size box you need to build first, as cubic footage needed will vary, and the sub will sound different based on the volume of the box.
well it pretty hard puting a sub anywhere else b/c in a notch there is no where lol.................in my friends FORD FESTIVA he has a sub in the back facing backwards (toward the back window) and it pretty damn loud still
ORIGINAL: HC_CrAzYHoRsE
that's where mine is... i bought the box at a local place and it fit right in perfectly.
