??? on fiberglass
Old 03-08-2007, 04:07 PM
nickr182002
nickr182002's Avatar
Default ??? on fiberglass
ok just to review. I have tworusted throughholes in my roof on both sides of the sunroof. They are about 1-2 inches wide and about 4 inches long.( not complete holes. There is some metal there but its just rusted through)I am thinking about using fiberglass to try and make it look somewhat decent.Can this be done?If i can do this, should i use the fiberglass from the inside of the car or the outside of the car? Im not going for perfection, i just dont want to see these holes anymore. Rest of the body isn't bad. Thanks for any advise.
nickr182002 is offline
Old 03-08-2007, 06:01 PM
Evil_F
Evil_F's Avatar
Default RE: ??? on fiberglass
1)Take a wire brush wheel and remove all of the rust. If not it will just grow like a cancer.
2)Take some Rustoleum Primer and spray on the freshly brushed area and let dry
3)Yes, fiberglass from the inside of the car to patch the hole.
4)Bondo the spot from the exterior and sand smooth.
5)reprimer then Paint
I have read where they say to patch from the exterior side with the fibreglass. But trust me, it is better to do it from the inside. Only time to patch on the exterior is when you are building up a large dent or something. You can make it nearly flawless the way I said above.
Evil_F is offline
Evil_F
Evil_F's Avatar
***oops*** twin post delete
Evil_F is offline
Old 03-09-2007, 08:53 AM
nickr182002
Wow. Thank you very much. Now i just need to learn how to fiberglass and i should be ok.LOL. j/k
svastano
25
07-16-2016 01:20 PM
StangFive89
11-09-2004 07:17 PM
Dveres95
08-30-2004 02:12 AM
draconis4756
08-11-2004 06:17 PM
Mavrik
06-25-2004 09:07 PM
Quick Reply: ??? on fiberglass
