URGET! smog removal help needed
RE: URGET! smog removal help needed
When you go to ace or wherever... look for 5/8-11 and than look for nothing bigger thana 3/4"...
I forget what size mine were but they were bigger... you need to get them as short as possible because there is literally NO room to get the bolts in so the longer they are the harder they will be to put in because they will be up agaist the firewell. Make sure you spray some degreaser or something into the holes and stick a paper towl in there and clean all the sh*t out of there... the more junk in the heads the harder its going to be to put them in. With some bullsh*tting and drinking it took me like two hours just to get the head bolts in [&:]
ORIGINAL: 88BlueGT
You put the bolt in... and than turn it [8D]
ORIGINAL: deanzawistowski
im kinda confused on what size bolt to get
and how did you thread in the bolt?
i might be retarded then because i couldnt get it to thread in, obliviously there was not threads in that hole and there was way to much gunk to be able to thread it so I just took the old pieces from the tube that sent the air and cut them off and then welded them shut then just bolted them back up over the holes
dochawk
08-25-2015 08:25 AM
Figure8allday
08-22-2015 11:11 AM
