Need new axles
Need new axles
I spun a bearing in my rearend and it screwed up my axle. So i need advice on what axles to get. I wanna try to keep it 4 lug and i want something to hold some power. Any ideas? Thnx!
RE: Need new axles
are you going to go with 31 spline? that would be a lot stronger but you would have to buy a new carrier. i bought the 28 spline alloy usa ones from summit and i like them. my splines were messed up so bad the axles would skip in the carrier a little and the ends where the bearing are they were all pitted. there are lots to choose from. alloy usa were the least expensive i could find.
RE: Need new axles
I got a set of 28 spline mosers
the spline count will determine the od of the axle, a 31 spline one will be larger than the 28 spline and if you get 31 spline axles you need to get 31 spline carrier
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
