Fuel Pump, in tank?
Fuel Pump, in tank?
I have a 1995 Cobra, bone stock thank you, and the fuel pump went out. I wasn't sure if they were in tank? If so would this BBK 155 lph pump work and be enough with the 19 pound injectors? Second one down http://www.jegs.com/webapp/wcs/store...52953_-1_10307
RE: Fuel Pump, in tank?
The pump is in the tank...and its a piece of cake to drop. Unbolt the filler neck, and get a tranny jack to support the tank itself. Take down the 2 straps and it should come straight down. I just re-did my filler neck seal Monday and it took me all of 5 minutes to lower the tank. And if you are going to be replacing the pump to a better one, just spend the extra cash for a 255 and never worry about it again. Its only ~$20 more and it is well worth it. The extra fuel will be returned to the tank and your mileage wont suffer. Injectors will also be fine.
ORIGINAL: aode06
i dont care how easy that looks, that heavy tank drop down on you , youll be pissed, be carefull and use a brass punch or screwdriver, nothing steel that will spark.
mrappe
09-26-2015 10:16 AM
