motor knocks so hard but doesn't use any oil *now with Video*
RE: motor knocks so hard but doesn't use any oil
i don't mind GM's just like every other comany they made a couple motors that are junk and u just have to research b4 u buy
ORIGINAL: aode06
y would a knocking engine use oil?
i dont care for gm's this is one reason out of many
ORIGINAL: aode06
put some saw dust in it or turn up the radio
Jasper. Its more than likely a spun bearing. So the longer you run it, the worse its going to get. Your best option is going to be trying to source a semi-low miles shortblock and doing a hone/re-ring and re-bearing.
FYI.......Check the harmonic balancer....typical failure BTW, and cause for the knock sound in 3.1L, 3.4L and 3.8L gm engines......the noise is so loud, you think the engine has gone KAPUT.....I've replaced my share of HB's on those.
well i am about to go outside and record a short vid of the car running you all can help analyze whats wrong with it. i bet some will get a good laugh i know 94gtcoupe said he would. i will also walk away a good couple feet and i bet money u will still be able to hear it. so give me some time to record it and upload it
ORIGINAL: Jasperstang308
wouldn't the motor shake bad if that was the case?
