How much power?
How much power?
I am going to build a new 347 and I got to thinking that I might use one of Ford Racing's short blocks as a base for it. Anyway my question is how much power will the forged 347 short block hold? I am looking to make around 650HP on the motor using nitrous. This is the short block I am looking at: 347 Stroker
Thanks for the help
Thanks for the help
RE: How much power?
any 5.0 stock block shouldnt be pushed past 500hp is your worried about hte reliability of it.... 650 would probably result in a cracked block... u should look into an aftermarket block which are expinsive or find u a nice 351 and u can stock that to 408 or 427... there almos the same as a 302 just different deck height... a lot of stuff will switch over too so its not like you buying a completely new engine. a 351 could easily handle the 650 hp your talking about and can be had for a fraction of the cost of a dart block.... look for a mexican 351 they are much strong that others and can hold even more hp than a regular 351
as for you questoin tho no a 302 will not be able to take 650hp for very long... ull be on borrowed time... which is never good
RE: How much power?
Are you talking about the new boss 302 block? 650 HP is going to require much more $/mods. I'm just about at 500 with a 347 stroker, 42 lb. ing, a Vortech SC, a custom grind blower cam, Canfield 195 heads, a Pro M 90 MM MAF, 255 lph FP with T-rex ext. FP. etc., so it's all a matter opf how far you want to go.
RE: How much power?
PLEASE ..... do NOT get a Ford Racing short block.
They use cheap vendors now.
find you a local "race engine" shop and have them build it.
i firmly believe that doing mail order engines is a HUGE mistake
Who you going to turn to if something is wrong or breaks? going to ship it back?
PLEASE PLEASE PLEASE, find you a good local "Ford" engine builder
and what they said, if you want 650hp you need a $1500-2,000 aftermarket block
or................
you could do a 351W swap like me, they are good for 650-700hp and come
with more cubes in stock stroke.
or................
RE: How much power?
ORIGINAL: tjmon1
Buy a Mexican short block. They are good for over 700 HP
alloy used in casting. And I've read even that is myth.
You want over 500hp on a 302 block and you want it to last
you need a 4 bolt main block. ---- Dart Sportsman, Dart IronEagle or new Ford Boss block.
RE: How much power?
I've heard Mexican blocks are good for about 600. When I had my engine built they went with an early model block because I'm not looking to make much more than 500.
Listen to r.barn. You'll need a 4 bolt main and I also agree with the engine shop route. That's exactly what I did.
