compression test results.
#21
RE: compression test results.
ORIGINAL: hatchdemon89
with my old motor i was buring oil badd an had low compression i replaced my guide seals compression went up an didn't smoke anymore
#26
ORIGINAL: StrongStang50
how much oil do I put in the spark plug hole to complete this test? Other than that do I complete it the same way as I would without the oil?
#27
I am just confused on exactly how I track the problem so I can pinpoint specificallywhats wrong. If its the rings I need to start an enginebuild. If its the heads I need to order heads. Spring is coming QUICK! thanks for all your help guys!
#29
A good 302 hits 130-160. I have over 100K miles on mine and it hit 160 on all eight in three or less strokes. Your motor is shot. Typically less than 100psi wont hit at idle. The smoke likely indicates an issue with the bottom end, but a wet test is not the most accurate way to find your compression loss. Too much oil andyou will seal a valve. Wet tests are for people without the proper tools.You need to put compressed air in each cylinder when at TDC and listen for where the air is going. Some will natually leak past the rings. What is considered too much will require a bit of "feel" or at least some experience. You can use a rubber glove on the throttle body and tailpipe to identify a valve loss if it is not easily heard. Removal of your rocker arms may yield an upper valvetrain issue. I have seen engines that had bent rocker arms or broken valvesprings cause leakage. The likelihood of this being the case for you is pretty slim considering what cylinders are affected. Leakage test all the way, but regardless of where the leakage may be coming from - you will need a new bottom end or heads. Personally, I would just rebuild the motor and not try to "band-aid" your low compression on all eight.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
