fuel pump problems
fuel pump problems
ok this crap is starting to pist me off. its the only thing that is keeping me from having my car running. the fuel pump works, i tested it and it spits gas great. how would i test to see if its getting power or not? also if its not getting power whats the best way to fix it? thanks,
RE: fuel pump problems
back probe your connector at the gas tank. and turn the ignition to accessory and look for voltage. If no voltage there, check for bad ground, broken connetion in harness, or broken wire along the way.
