ebay MAF conversion kit?
RE: ebay MAF conversion kit?
Here is something I posted a while back and saved the info...
Anotheroption would be the MAF/MAS from a 94-95 Mustang.
This is a 70mm tube, which is a direct swap for an A9* computer, as long as the 19's are still in use.
Here is a list of some of the Factory uses for this meter...
94-95 Mustang 5.0
94-95 Mustang 3.8
94-95 Mustang Cobra 5.0
92-94 Crown Vic 4.6
but there may be others.
the important features are...
70mm tube diameter
part number 'F2VF' on the MAS (the little black sensor box)
This meter would be a mild performance upgrade, worth a couple (5-7)HP.
The only 'converting' required is an inlet tube adapter. I can't find a good link right now, but they are available.
If nothing else, some guys have simply cut the flange off the 70mm housing and slipped their inlet hose over the MAF (similar to the original setup).
If you can't find one of these 70mmmeters...
The factory meter for the MAF Mustang 5.0 was a 55mm tube with a 'F1ZF' MAS.
This sensor was also available on...
88-93 Mustang 5.0
89-95 Taurus SHO 3.0
88-93 T-Bird 3.8
92-93 T-Bird 5.0
94-95 Mustang 5.0
94-95 Mustang 3.8
92-94 Crown Vic 4.6
70mm tube diameter
88-93 Mustang 5.0
88-93 T-Bird 3.8
92-93 T-Bird 5.0
hey man thanks for the pointers and such. my motor is completly stock and i mean stock. having some fuel pump issues but when i get those issues fixed then i plan on upgrading to mass air. i don't mind learing how to splice things but i don't want to splice the wrong thing etc. i don't have any of the MAF parts yet and i am looking for the right ones. price is not really a issue under $1000. i was thinking about the plug and play route would be the best for me and my application. so if you could give me some pointers on where to start and what not that would be very helpful as i am pretty much clueless. thanks man!
Most of the computers are similar enough to each other that there will not be a performance advantage with one versus another.
The A9L (manual)or A9P (auto)will work really well. Most of the conversion kits will come with an A9* series computer.
Most of these kits will come with a Fox 55mm MAF tube. It is recommended to find a 70mm tube (as listed in post #10) to replace the 55mm unit.
That MAF upgrade will yeild a little power, as the 55mm units are a mild restriction.
jwog666
12-27-2021 08:09 PM
